Optimising Light Source Spectrum to Reduce the Energy Absorbed by Objects
Durmus, DorukalpAbstract
Light is used to illuminate objects in the built environment. Humans can only observe light reflected from an object. Light absorbed by an object turns into heat and does not contribute to visibility. Since the spectral output of the new lighting technologies can be tuned, it is ...
See moreLight is used to illuminate objects in the built environment. Humans can only observe light reflected from an object. Light absorbed by an object turns into heat and does not contribute to visibility. Since the spectral output of the new lighting technologies can be tuned, it is possible to imagine a lighting system that detects the colours of objects and emits customised light to minimise the absorbed energy. Previous optimisation studies investigated the use of narrowband LEDs to maximise the efficiency and colour quality of a light source. While these studies aimed to tune a white light source for general use, the lighting system proposed here minimises the energy consumed by lighting by detecting colours of objects and emitting customised light onto each coloured part of the object. This thesis investigates the feasibility of absorption-minimising light source spectra and their impact on the colour appearance of objects and energy consumption. Two computational studies were undertaken to form the theoretical basis of the absorption-minimising light source spectra. Computational simulations show that the theoretical single-peak spectra can lower the energy consumption up to around 38 % to 62 %, and double-peak test spectra can result in energy savings up to 71 %, without causing colour shifts. In these studies, standard reference illuminants, theoretical test spectra and coloured test samples were used. These studies are followed by the empirical evidence collected from two psychophysical experiments. Data from the experiments show that observers find the colour appearance of objects equally natural and attractive under spectrally optimised spectra and reference white light sources. An increased colour difference, to a certain extent, is found acceptable, which allows even higher energy savings. However, the translucent nature of some objects may negatively affect the results.
2017-10-21Licence
Sydney School of Architecture, Design and PlanningAwarding institution
