Stability and Dynamics of Bragg Grating Solitons in a semilinear Dual-Core System with Cubic-Quintic Nonlinearity
Jahirul Islam, MdAbstract
Bragg grating soliton dynamics in a semilinear coupler, in which one core has Bragg grating with cubic-quintic nonlinearity and the other is linear are studied. The system's linear spectrum contains two bandgaps, namely the upper and lower gaps when the group velocity mismatch term ...
See moreBragg grating soliton dynamics in a semilinear coupler, in which one core has Bragg grating with cubic-quintic nonlinearity and the other is linear are studied. The system's linear spectrum contains two bandgaps, namely the upper and lower gaps when the group velocity mismatch term c in the linear core is zero. For c ≠ 0, an additional genuine central gap results in. In the moving case, three bandgaps exist. For quiescent cases, the edges of the bandgaps are almost independent of c for a given coupling coefficient κ. However, in the case of moving solitons, the bandgap edges strongly depend on soliton velocity s and group velocity mismatch c. The system supports two disjoint families of solitons, referred to as ‘Type 1’ and ‘Type 2’; both of which exist throughout the upper and lower gaps only. The stability of solitons is investigated using systematic numerical techniques. Investigations reveal that all Type 2 solitons are highly unstable, while vast regions exist where Type 1 solitons are stable. The stability border depends on system parameters, such as q, κ, c and s. The presence of quintic nonlinearity greatly improves the robustness of the solitons. The interaction dynamics of co-propagating solitons gives rise to several interesting outcomes. Generally, in-phase solitons attract and out-of-phase solitons repel. In-phase interactions result in a variety of outcomes, such as destruction of the solitons; symmetric or asymmetric separation; and, more interestingly, the fusion into a single one and 2→3 transformation. Further, collisions of stable counter-propagating solitons are systematically investigated. In-phase collisions exhibit diverse outcomes, which may include passage through with unchanged, reduced, increased or different velocities; destruction of the solitons; merger into a single one; and three soliton process. The merger and three soliton process are mostly significant and may have potential applications in slow light generation.
2016-08-31Licence
