Please use this identifier to cite or link to this item: http://hdl.handle.net/2123/985
Title: Random Matrix Theory Analysis of Fixed and Adaptive Linear Receivers
Authors: Peacock, Matthew James McKenzie
Keywords: Large-System
MMSE
Recursive Least Squares
MIMO
CDMA
Issue Date: 26-Aug-2005
School of Electrical and Information Engineering
Abstract: This thesis considers transmission techniques for current and future wireless and mobile communications systems. Many of the results are quite general, however there is a particular focus on code-division multiple-access (CDMA) and multi-input multi-output (MIMO) systems. The thesis provides analytical techniques and results for finding key performance metrics such as signal-to-interference and noise power ratios (SINR) and capacity. This thesis considers a large-system analysis of a general linear matrix-vector communications channel, in order to determine the asymptotic performance of linear fixed and adaptive receivers. Unlike many previous large-system analyses, these results cannot be derived directly from results in the literature. This thesis considers a first-principles analytical approach. The technique unifies the analysis of both the minimum-mean-squared-error (MMSE) receiver and the adaptive least-squares (ALS) receiver, and also uses a common approach for both random i.i.d. and random orthogonal precoding. The approach is also used to derive the distribution of sums and products of free random matrices. Expressions for the asymptotic SINR of the MMSE receiver are derived, along with the transient and steady-state SINR of the ALS receiver, trained using either i.i.d. data sequences or orthogonal training sequences. The results are in terms of key system parameters, and allow for arbitrary distributions of the power of each of the data streams and the eigenvalues of the channel correlation matrix. In the case of the ALS receiver, we allow a diagonal loading constant and an arbitrary data windowing function. For i.i.d. training sequences and no diagonal loading, we give a fundamental relationship between the transient/steady-state SINR of the ALS and the MMSE receivers. We demonstrate that for a particular ratio of receive to transmit dimensions and window shape, all channels which have the same MMSE SINR have an identical transient ALS SINR response. We demonstrate several applications of the results, including an optimization of information throughput with respect to training sequence length in coded block transmission.
Description: Doctor of Philosophy (PhD)
URI: http://hdl.handle.net/2123/985
01front.pdfFront464.28 kBAdobe PDFView/Open
02whole.pdfBody2.23 MBAdobe PDFView/Open
