http://hdl.handle.net/2123/919
| Title: | Magnetorotational Instability in Protostellar Discs |
| Authors: | Salmeron, Raquel |
| Keywords: | accretion discs instabilities magnetorotational instability MHD star formation |
| Issue Date: | 19-Aug-2004 |
| Publisher: | Physics |
| Abstract: | We investigate the linear growth and vertical structure of the magnetorotational instability (MRI) in weakly ionised, stratified accretion discs. The magnetic field is initially vertical and perturbations have vertical wavevectors only. Solutions are obtained at representative radial locations from the central protostar for different choices of the initial magnetic field strength, sources of ionisation, disc structure and configuration of the conductivity tensor. The MRI is active over a wide range of magnetic field strengths and fluid conditions in low conductivity discs. For the minimum-mass solar nebula model, incorporating cosmic ray and x-ray ionisation and assuming that charges are carried by ions and electrons only, perturbations grow at 1 AU for B < 8G. For a significant subset of these strengths (200mG < B < 5 G), the growth rate is of order the ideal MHD rate (0.75 Omega). Hall conductivity modifies the structure and growth rate of global unstable modes at 1 AU for all magnetic field strengths that support MRI. As a result, at this radius, modes obtained with a full conductivity tensor grow faster and are active over a more extended cross-section of the disc, than perturbations in the ambipolar diffusion limit. For relatively strong fields (e.g. B > 200 mG), ambipolar diffusion alters the envelope shapes of the unstable modes, which peak at an intermediate height, instead of being mostly flat as modes in the Hall limit are in this region of parameter space. Similarly, when cosmic rays are assumed to be excluded from the disc by the winds emitted by the magnetically active protostar, unstable modes grow at this radius for B < 2 G. For strong fields, perturbations exhibit a kink at the height where x-ray ionisation becomes active. Finally, for R = 5 AU (10 AU), unstable modes exist for B < 800 mG (B < 250 mG) and the maximum growth rate is close to the ideal-MHD rate for 20 mG < B < 500 mG (2 mG < B < 50 mG). Similarly, perturbations incorporating Hall conductivity have a higher wavenumber and grow faster than solutions in the ambipolar diffusion limit for B < 100 mG (B < 10 mG). Unstable modes grow even at the midplane for B > 100 mG (B ~ 1 mG), but for weaker fields, a small dead region exists. When a population of 0.1 um grains is assumed to be present, perturbations grow at 10 AU for B < 10 mG. We estimate that the figure for R = 1 AU would be of order 400 mG. We conclude that, despite the low magnetic coupling, the magnetic field is dynamically important for a large range of fluid conditions and field strengths in protostellar discs. An example of such magnetic activity is the generation of MRI unstable modes, which are supported at 1 AU for field strengths up to a few gauss. Hall diffusion largely determines the structure and growth rate of these perturbations for all studied radii. At radii of order 1 AU, in particular, it is crucial to incorporate the full conductivity tensor in the analysis of this instability, and more generally, in studies of the dynamics of astrophysical discs. |
| Description: | Doctor of Philosophy |
| URI: | http://hdl.handle.net/2123/919 |
| Rights and Permissions: | The author retains copyright of this thesis. |
| Type of Work: | PhD Doctorate |
