Efficient Methods for Predicting Soil Hydraulic Properties
Minasny, BudimanAbstract
Both empirical and process-simulation models are useful for evaluating the effects of management practices on environmental quality and crop yield. The use of these models is limited, however, because they need many soil property values as input. The first step towards modelling ...
See moreBoth empirical and process-simulation models are useful for evaluating the effects of management practices on environmental quality and crop yield. The use of these models is limited, however, because they need many soil property values as input. The first step towards modelling is the collection of input data. Soil properties can be highly variable spatially and temporally, and measuring them is time-consuming and expensive. Efficient methods, which consider the uncertainty and cost of measurements, for estimating soil hydraulic properties form the main thrust of this study. Hydraulic properties are affected by other soil physical, and chemical properties, therefore it is possible to develop empirical relations to predict them. This idea quantified is called a pedotransfer function. Such functions may be global or restricted to a country or region. The different classification of particle-size fractions used in Australia compared with other countries presents a problem for the immediate adoption of exotic pedotransfer functions. A database of Australian soil hydraulic properties has been compiled. Pedotransfer functions for estimating water-retention and saturated hydraulic conductivity from particle size and bulk density for Australian soil are presented. Different approaches for deriving hydraulic transfer functions have been presented and compared. Published pedotransfer functions were also evaluated, generally they provide a satisfactory estimation of water retention and saturated hydraulic conductivity depending on the spatial scale and accuracy of prediction. Several pedotransfer functions were developed in this study to predict water retention and hydraulic conductivity. The pedotransfer functions developed here may predict adequately in large areas but for site-specific applications local calibration is needed. There is much uncertainty in the input data, and consequently the transfer functions can produce varied outputs. Uncertainty analysis is therefore needed. A general approach to quantifying uncertainty is to use Monte Carlo methods. By sampling repeatedly from the assumed probability distributions of the input variables and evaluating the response of the model the statistical distribution of the outputs can be estimated. A modified Latin hypercube method is presented for sampling joint multivariate probability distributions. This method is applied to quantify the uncertainties in pedotransfer functions of soil hydraulic properties. Hydraulic properties predicted using pedotransfer functions developed in this study are also used in a field soil-water model to analyze the uncertainties in the prediction of dynamic soil-water regimes. The use of the disc permeameter in the field conventionally requires the placement of a layer of sand in order to provide good contact between the soil surface and disc supply membrane. The effect of sand on water infiltration into the soil and on the estimate of sorptivity was investigated. A numerical study and a field experiment on heavy clay were conducted. Placement of sand significantly increased the cumulative infiltration but showed small differences in the infiltration rate. Estimation of sorptivity based on the Philip's two term algebraic model using different methods was also examined. The field experiment revealed that the error in infiltration measurement was proportional to the cumulative infiltration curve. Infiltration without placement of sand was considerably smaller because of the poor contact between the disc and soil surface. An inverse method for predicting soil hydraulic parameters from disc permeameter data has been developed. A numerical study showed that the inverse method is quite robust in identifying the hydraulic parameters. However application to field data showed that the estimated water retention curve is generally smaller than the one obtained in laboratory measurements. Nevertheless the estimated near-saturated hydraulic conductivity matched the analytical solution quite well. Th author believes that the inverse method can give a reasonable estimate of soil hydraulic parameters. Some experimental and theoretical problems were identified and discussed. A formal analysis was carried out to evaluate the efficiency of the different methods in predicting water retention and hydraulic conductivity. The analysis identified the contribution of individual source of measurement errors to the overall uncertainty. For single measurements, the inverse disc-permeameter analysis is economically more efficient than using pedotransfer functions or measuring hydraulic properties in the laboratory. However, given the large amount of spatial variation of soil hydraulic properties it is perhaps not surprising that lots of cheap and imprecise measurements, e.g. by hand texturing, are more efficient than a few expensive precise ones.
2000-01-01Licence
Copyright Minasny, Budiman;http://www.library.usyd.edu.au/copyright.htmlThe author retains copyright of this thesis
Faculty/School
Faculty of AgricultureDepartment, Discipline or Centre
Department of Agricultural Chemistry and Soil Science, Land, Water & Crop SciencesAwarding institution
