Please use this identifier to cite or link to this item: http://hdl.handle.net/2123/821
Title: TWO PATHWAYS OF SHEDDING OF L-SELECTIN AND CD23 FROM HUMAN B-LYMPHOCYTES
Authors: Gu, Baijun
Keywords: L-selectin;CD62L;CD23;transmigration;P2X7;B-CLL
Issue Date: 30-Mar-2006
Abstract: Lymphocytes from patients with B-chronic lymphocytic leukemia (B-CLL) express large numbers of P2X7 receptors for extracellular adenosine triphosphate (ATP). Activation of P2X7 receptors induces multiple downstream effects, of which the best documented is the opening of an ionic channel that is selective for divalent cations. Another effect of ATP is to induce the shedding of L-selectin (CD62L), a molecule which is involved in the adhesive interactions of lymphocytes on endothelial cells. High levels of soluble L-selectin and CD23 are found in the serum of patients with B-CLL, although the mechanisms involved in their production are poorly characterized. Because extracellular ATP causes shedding of L-selectin, we studied the effect of ATP on shedding of CD23, an adhesion molecule expressed on the surface of B-CLL lymphocytes. ATP induced the shedding of CD23 at an initial rate of 12% of that for L-selectin, while the EC50 of ATP (35 uM) and BzATP (10 uM) was identical for shedding of both molecules. Inactivation of the P2X7 receptor by pre-incubation with OxATP, an irreversible inhibitor of P2X7 purinoceptor, abolished ATP-induced shedding of both molecules. Moreover, KN-62, the most potent inhibitor for the P2X7 receptor inhibited ATP-induced shedding of both CD23 and L-selectin with the same IC50 (12 nM). Ro 31-9790, a membrane permeant zinc chelator which inhibits the phorbol-ester stimulated shedding of L-selectin also inhibited shedding of CD23 from B-CLL lymphocytes, but the IC50 was different for the two shed molecules (25 versus 1 ug/ml respectively). Although L-selectin was completely shed by incubation of cells with phorbol-ester no CD23 was lost under these conditions. Also, Ca2+ inhibits ATP-induced CD23 shedding but not L-selectin shedding. Since soluble CD23 and L-selectin are found in the serum of normal subjects and B-CLL patients, the expression of these two adhesion molecules on lymphocytes before and after transendothelial migration was studied in an in vitro model of this process. In normal and B-CLL subjects, 71�b5% of L-selectin from both T and B cells and 90% of CD23 from B cells was lost following transmigration, while the expression of a range of other adhesion molecules such as VLA-4, ICAM-1, LFA-1 and CD44 was unchanged. Lymphocytes incubated with OxATP retained their capacity for transendothelial migration and showed the same loss of L-selectin as control leukaemic lymphocytes. Ro 31-9790, which can protect ATP-induced both L-selectin and CD23 shedding, had no effect on inhibiting L-selectin and CD23 lost during transmigration. These data show the presence of a second pathway for the downregulation of L-selectin and CD23 from the lymphocyte surface. Data in vivo from 'knock-out' mice show that L-selectin is essential for the emigration of lymphocytes through high endothelial venules into lymph nodes. The migration of normal and B-CLL lymphocytes across confluent human umbilical vein endothelial monolayers was studied in an in vitro model of this process. Lymphocytes treated with ATP or BzATP showed 56�b25% or 67�b16% loss of L-selectin on the surface and 36�b24% or 64�b19% decrease of transmigration, respectively, while OxATP, which does not alter the L-selectin level, had no effect on lymphocyte transmigration. Further experiments examined this correlation between L-selectin expression and lymphocyte transendothelial migration in this model system. A quantitative assay for cell surface L-selectin showed that expression of L-selectin was lower on B-CLL lymphocytes (8,880�b5,700 molecules/cell) than on normal lymphocytes (29,500�b7,500 molecules/cell, p less than 0.001). Also the rate of transmigration of B-CLL lymphocytes (1.5�b0.9 migrated cells/HUVEC) was lower than normal peripheral lymphocytes (2.4�b0.9 migrated cells/HUVEC, p=0.04). Incubation of lymphocytes in complete medium for 24 hrs increased the expression of L-selectin on B-CLL lymphocytes by 1.5 to 2 fold while the normal lymphocyte L-selectin remained at the initial level. This upregulation of B-CLL L-selectin correlated with a 2 fold increased rate of transendothelial migration. A correlation was found between L-selectin expression on lymphocytes and their ability for transendothelial migration (r^2=0.6). This study shows that the adhesion molecules L-selectin and CD23 can be lost from lymphocytes by two different physiological pathways. One is by P2X7 receptor activation by extracellular ATP while the second is activated by transendothelial migration of these cells. A second finding is that B-CLL lymphocytes have lower level of L-selectin expression and an impaired ability for transendothelial migration compared with normal peripheral blood lymphocytes. Do these results explain the high serum levels of soluble L-selectin and CD23 observed in B-CLL? Although B-CLL lymphocytes do not recirculate as rapidly as normal peripheral blood lymphocytes, the greatly increased number of leukaemic cells in B-CLL ensures that much more soluble L-selectin and CD23 is generated during the recirculation of these cells through the body.
URI: http://hdl.handle.net/2123/821
adt-NU20020129.00353802whole-gu.pdf3.55 MBAdobe PDFView/Open
adt-NU20020129.00353801front-gu.pdf184.86 kBAdobe PDFView/Open
