Please use this identifier to cite or link to this item: http://hdl.handle.net/2123/811
Title: Simulating and assessing salinisation in the lower Namoi Valley
Authors: Ahmed, Mohammad Faruque
Keywords: salinisation;disjunctive kriging;misclassification;leaching fraction;electromagnetic induction
Issue Date: 30-Mar-2006
Publisher: University of Sydney. Land Water and Crop Sciences
Abstract: Dryland salinity is increasing in the upper catchments of central and northern New South Wales, Australia. Consequently, salts may be exported downstream, which could adversely affect cotton irrigated-farming systems. In order to assess the potential threat of salinity a simple salt balance model based on progressively saline water (i.e., ECiw 0.4, 1.5, 4.0 and 9.0 dS/m) was used to simulate the potential impact of salinisation due to the farming systems. The study was carried out in the lower Namoi valley of northern New South Wales, Australia. A comparison has been made of the various non-linear techniques (indicator kriging, multiple indicator kriging and disjunctive kriging) to determine an optimal simulation method for the risk assessment. The simulation results indicate that potential salinisation due to application of the water currently used for irrigation (ECiw) is minimal and may not pose any problems to sustainability of irrigated agriculture. The same results were obtained by simulation based on irrigation using slightly more saline water (ECiw 1.4 dS/m). However, simulations based on irrigation using water of even lower quality (ECiw of 4 and 9.0 dS/m), shows potential high salinisation, which will require management inputs for sustainable cropping systems, especially legumes and wheat, which are used extensively in rotation with cotton. Disjunctive kriging was the best simulation method, as it produced fewer misclassifications in comparison with multiple-indicator kriging and indicator kriging. This study thus demonstrates that we can predict the salinity risk due to application of irrigation water of lower quality than that of the current water used. In addition, the results suggest here problems of excessive deep drainage and inefficient use of water might be a problem. The second part of this thesis deals with soil information required at the field scale for management practices particularly in areas where deep drainage is large. Unfortunately, traditional methods of soil inventory at the field level involve the design and adoption of sampling regimes and laboratory analysis that are time-consuming and costly. Because of this more often than not only limited data are collected. In areas where soil salinity is prevalent, detailed quantitative information for determining its cause is required to prescribe management solutions. This part deals with the description of a Mobile Electromagnetic Sensing System (MESS) and its application in an irrigated-cotton field suspected of exhibiting soil salinity. The field is within the study area of part one of this thesis-located about 2 km south west of Wee Waa. The EM38 and EM31 (ECa) data provide information, which was used in deciding where soil sample sites could be located in the field. The ECa data measured by the EM38 instrument was highly correlated with the effective cation exchange capacity. This relationship can be explained by soil mineralogy. Using different soil chemical properties (i.e. ESP and Ca/Mg ratio) a detailed transect study was undertaken to measure soil salinity adjoining the water storage. It is concluded that the most appropriate management option to remediation of the problem would be to excavate the soil directly beneath the storage floor where leakage is suspected. It is recommended that the dam not be enlarged from its current size owing to the unfavourable soil mineralogy (i.e. kaolin/illite) located in the area where it is located.
URI: http://hdl.handle.net/2123/811
adt-NU20021031.16453701front.pdf225.59 kBAdobe PDFView/Open
adt-NU20021031.16453702whole.pdf4.24 MBAdobe PDFView/Open
