Efficient Timing of Retirement
Working PaperAuthor/s
Kingston, GeoffreyAbstract
A fundamental question in personal finance is deciding when to retire. This article is a theoretical investigation within a conventional life-cycle setting. It finds two closed-form solutions to the retirement timing problem. One solution, based on an isoelastic form of the utility ...
See moreA fundamental question in personal finance is deciding when to retire. This article is a theoretical investigation within a conventional life-cycle setting. It finds two closed-form solutions to the retirement timing problem. One solution, based on an isoelastic form of the utility function and a non-negative rate of time preference, identifies nine variables that could affect the retirement decision. The other formula, based on a log form of the utility function and a zero rate of time preference, sees the number of variables reduced to four. This simplified formula is especially easy to interpret, and could be of particular use to empirical researchers and financial planners.
1999-02-01Issue
3Publisher
Department of EconomicsLicence
Faculty of Arts and Social Sciences, School of EconomicsShare
