Please use this identifier to cite or link to this item: http://hdl.handle.net/2123/686
Title: Mapping the proteome of Streptococcus gordonii
Authors: Macarthur, Deborah Jane
Keywords: chemostat;dental plaque;environmental pH;infective endocarditis;mass spectometry;oral ecology;proteome proteomics;Streptococcus gordonii
Issue Date: 27-Mar-2006
Publisher: University of Sydney. Health Science
Abstract: Streptococcus gordonii is a primary coloniser of the tooth surface where it efficiently ferments carbohydrates at pH levels above 6.0. By not being able to maintain the pH of dental plaque to a level required for enamel dissolution, the dominance of S. gordonii in dental plaque is considered a sign of a healthy oral cavity. However, upon entering the bloodstream and encountering a rise in pH, S. gordonii may become pathogenic, being one of the major causative organisms associated with infective endocarditis. Proteome analyses of S. gordonii grown at steady state in a chemostat allowed the phenotypic changes associated with alterations in pH levels characteristic of these two environments to be determined. As an initial starting point to this study, a two-dimensional electrophoresis (2- DE) reference map of S. gordonii grown at pH 7.0 was produced. Although only 50% of the S gordonii genome was available in an annotated form during the course of this study, the closely related Streptococcus pneumoniae genome (with which S. gordonii shares 97.24% DNA sequence homology) had been completed in 2001. The use of both of these databases allowed many of the S. gordonii proteins to be identified by mass spectrometry. Four hundred and seventy six protein spots, corresponding to 250 different proteins, or 12.5% of the S. gordonii proteome, were identified, giving rise to the first comprehensive proteome reference map of this oral bacterium. Of the 250 different proteins, 196 were of cellular origin while 68 were identified from the extracellular milieu. Only 14 proteins were common to both compartments. Of particular interest among the 54 uniquely identified extracellular proteins was a homologue of a peptidoglycan hydrolase that has been associated with virulence in S. pneumoniae. Among the other proteins identified were ones involved in transport and binding, energy metabolism, translation, transformation, stress response and virulence. Twelve cell envelope proteins were identified as well as 25 others that were predicted to have a membrane association based on the presence of at least one transmembrane domain. The study also confirmed the existence of 38 proteins previously designated as �hypothetical� or with no known function. Mass spectral data for over 1000 protein spots were accumulated and archived for future analysis when sequencing of the S. gordonii genome is finally completed. Following the mapping of the proteome of S. gordonii, alterations in protein spots associated with growth of the bacterium at pH intervals of 0.5 units in the pH range 5.5 - 7.5 were determined. Only 16 protein spots were shown to be significantly altered in their level of expression despite the range of pH studied. Among the differentially expressed proteins was a manganese-dependent inorganic pyrophosphatase (PpaC), which regulates expression of adhesins required for coaggregation. The expression of PpaC was highest at pH 6.5 - 7.0, the pH of a healthy oral cavity, indicating that PpaC may play an important part in dental plaque formation. Another differentially expressed protein was the heat-inducible transcription repressor (HrcA). Alterations in HrcA were consistent with its role as a negative repressor in regulating heat-shock proteins at low pH, even though no changes in the level of heat-shock proteins were observed as the pH declined. This result gave rise to the hypothesis that the possible reason cariogenic bacteria, such as Streptococcus mutans, can out compete S. gordonii at low pH might simply be due to their ability to manipulate their proteome in a complex manner for survival and persistence at low pH, unlike S. gordonii. This may imply some prevailing level of genetic regulation that is missing in S. gordonii.
URI: http://hdl.handle.net/2123/686
Rights and Permissions: Copyright Macarthur, Deborah Jane;http://www.library.usyd.edu.au/copyright.html
adt-NU20051007.14201101front.pdf619.63 kBAdobe PDFView/Open
adt-NU20051007.14201102whole.pdf8.75 MBAdobe PDFView/Open
