Please use this identifier to cite or link to this item: http://hdl.handle.net/2123/652
Title: PIEZOELECTRIC ACTUATOR DESIGN OPTIMISATION FOR SHAPE CONTROL OF SMART COMPOSITE PLATE STRUCTURES
Authors: Nguyen, Van Ky Quan
Keywords: Shape Control; Piezoelectric Actuators/Sensors; Composite Plates; Finite Element Analysis; Structural Optimisation; Sensitivity Analysis
Issue Date: 27-Mar-2006
Publisher: University of Sydney. Aerospace, Mechanical and Mechatronic
Abstract: Shape control of a structure with distributed piezoelectric actuators can be achieved through optimally selecting the loci, shapes and sizes of the piezoelectric actuators and choosing the electric fields applied to the actuators. Shape control can be categorised as either static or dynamic shape control. Whether it is a transient or gradual change, static or dynamic shape control, both aim to determine the loci, sizes, and shapes of piezoelectric actuators, and the applied voltages such that a desired structural shape is achieved effectively. This thesis is primarily concerned with establishing a finite element formulation for the general smart laminated composite plate structure, which is capable to analyse static and dynamic deformation using non-rectangular elements. The mechanical deformation of the smart composite plate is modelled using a third order plate theory, while the electric field is simulated based on a layer-wise theory. The finite element formulation for static and dynamics analysis is verified by comparing with available numerical results. Selected experiments have also been conducted to measure structural deformation and the experimental results are used to correlate with those of the finite element formulation for static analysis. In addition, the Linear Least Square (LLS) method is employed to study the effect of different piezoelectric actuator patch pattern on the results of error function, which is the least square error between the calculated and desired structural shapes in static structural shape control. The second issue of this thesis deals with piezoelectric actuator design optimisation (PADO) for quasi-static shape control by finding the applied voltage and the configuration of piezoelectric actuator patch to minimise error function, whereas the piezoelectric actuator configuration is defined based on the optimisation technique of altering nodal coordinates (size/shape optimisation) or eliminating inefficient elements in a structural mesh (topology optimisation). Several shape control algorithms are developed to improve the structural shape control by reducing the error function. Further development of the GA-based voltage and piezoelectric actuator design optimisation method includes the constraint handling, where the error function can be optimised subjected to energy consumption or other way around. The numerical examples are presented in order to verify that the proposed algorithms are applicable to quasi-static shape control based on voltage and piezoelectric actuator design optimisation (PADO) in terms of minimising the error function. The third issue is to use the present finite element formulation for a modal shape control and for controlling resonant vibration of smart composite plate structures. The controlled resonant vibration formulation is developed. Modal analysis and LLS methods are also employed to optimise the applied voltage to piezoelectric actuators for achieving the modal shapes. The Newmark direct time integration method is used to study harmonic excitation of smart structures. Numerical results are presented to induce harmonic vibration of structure with controlled magnitude via adjusting the damping and to verify the controlled resonant vibration formulation.
URI: http://hdl.handle.net/2123/652
adt-NU20051031.14014401front.pdf362.45 kBAdobe PDFView/Open
adt-NU20051031.14014402whole.pdf3.59 MBAdobe PDFView/Open
