Effect of temperature and photoperiod on broccoli development, yield and quality in south-east Queensland
ThesisAuthor/s
Tan, Daniel Kean YuenAbstract
Broccoli is a vegetable crop of increasing importance in Australia, particularly in south-east Queensland and farmers need to maintain a regular supply of good quality broccoli to meet the expanding market. However, harvest maturity date, head yield and quality are all affected by ...
See moreBroccoli is a vegetable crop of increasing importance in Australia, particularly in south-east Queensland and farmers need to maintain a regular supply of good quality broccoli to meet the expanding market. However, harvest maturity date, head yield and quality are all affected by climatic variations during the production cycle, particularly low temperature episodes. There are also interactions between genotype and climatic variability. A predictive model of ontogeny, incorporating climatic data including frost risk, would enable farmers to predict harvest maturity date and select appropriate cultivar - sowing date combinations. The first stage of this research was to define floral initiation, which is fundamental to predicting ontogeny. Scanning electron micrographs of the apical meristem were made for the transition from the vegetative to advanced reproductive stage. During the early vegetative stage (stage 1), the apical meristem was a small, pointed shoot tip surrounded by leaf primordia. The transitional stage (stage 2) was marked by a widening and flattening to form a dome-shaped apical meristem. In the floral initiation stage (stage 3), the first-order floral primordia were observed in the axils of the developing bracts. Under field conditions, the shoot apex has an average diameter of 500 micro m at floral initiation and floral primordia can be observed under a light microscope. Sub-zero temperatures can result in freezing injury and thereby reduce head yield and quality. In order to predict the effects of frosts, it is desirable to know the stages of development at which plants are most susceptible. Therefore, the effects of sub-zero temperatures on leaf and shoot mortality, head yield and quality were determined after exposure of plants to a range of temperatures for short periods, at different stages of development (vegetative, floral initiation and buttoning). Plants in pots and in the field were subjected to sub-zero temperature regimes from -1 C to -19 C. Extracellular ice formation was achieved by reducing temperatures slowly, at a rate of -2 C per hour. The floral initiation stage was most sensitive to freezing injury, as yields were significantly reduced at -1 C and -3 C, and shoot apices were killed at -5 C. There was no significant yield reduction when the inflorescence buttoning stage was subjected to -1 C and -3 C. Although shoot apices at buttoning survived the -5 C treatment, very poor quality heads of uneven bud size were produced as a result of arrested development. The lethal temperature for pot-grown broccoli was between -3 C and -5 C, whereas the lethal temperature for field-grown broccoli was between -7 C and -9 C. The difference was presumably due to variation in cold acclimation. Freezing injury can reduce broccoli head yield and quality, and retard plant growth. Crop development models based only on simple thermal time without restrictions will not predict yield or maturity if broccoli crops are frost-damaged. Field studies were conducted to develop procedures for predicting ontogeny, yield and quality. Three cultivars, (Fiesta, Greenbelt and Marathon) were sown on eight dates from 11 March to 22 May 1997, and grown under natural and extended (16 h) photoperiods in a sub-tropical environment at Gatton College, south-east Queensland, under non-limiting conditions of water and nutrient supply. Daily climatic data, and dates of emergence, floral initiation, harvest maturity, together with yield and quality were obtained. Yield and quality responses to temperature and photoperiod were quantified. As growing season mean minimum temperatures decreased, fresh weight of tops decreased while fresh weight harvest index increased linearly. There was no definite relationship between fresh weight of tops or fresh weight harvest index and growing season minimum temperatures greater than 10 C. Genotype, rather than the environment, mainly determined head quality attributes. Fiesta had the best head quality, with higher head shape and branching angle ratings than Greenbelt or Marathon. Bud colour and cluster separation of Marathon were only acceptable for export when growing season mean minimum temperatures were less than 8 C. Photoperiod did not influence yield or quality in any of the three cultivars. A better understanding of genotype and environmental interactions will help farmers optimise yield and quality, by matching cultivars with time of sowing. Crop developmental responses to temperature and photoperiod were quantified from emergence to harvest maturity (Model 1), from emergence to floral initiation (Model 2), from floral initiation to harvest maturity (Model 3), and in a combination of Models 2 and 3 (Model 4). These thermal time models were based on optimised base and optimum temperatures of 0 and 20 C, respectively. These optimised temperatures were determined using an iterative optimisation routine (simplex). Cardinal temperatures were consistent across cultivars but thermal time of phenological intervals were cultivar specific. Sensitivity to photoperiod and solar radiation was low in the three cultivars used. Thermal time models tested on independent data for five cultivars (Fiesta, Greenbelt, Marathon, CMS Liberty and Triathlon) grown as commercial crops on the Darling Downs over two years, adequately predicted floral initiation and harvest maturity. Model 4 provided the best prediction for the chronological duration from emergence to harvest maturity. Model 1 was useful when floral initiation data were not available, and it predicted harvest maturity almost as well as Model 4 since the same base and optimum temperatures of 0 C and 20 C, respectively, were used for both phenological intervals. Model 1 was also generated using data from 1979-80 sowings of three cultivars (Premium Crop, Selection 160 and Selection 165A). When Model 1 was tested with independent data from 1983-84, it predicted harvest maturity well. Where floral initiation data were available, predictions of harvest maturity were most precise using Model 3, since the variation, which occurred from emergence to floral initiation, was removed. Prediction of floral initiation using Model 2 can be useful for timing cultural practices, and for avoiding frost and high temperature periods. This research has produced models to assist broccoli farmers in crop scheduling and cultivar selection in south-east Queensland. Using the models as a guide, farmers can optimise yield and quality, by matching cultivars with sowing date. By accurately predicting floral initiation, the risk of frost damage during floral initiation can be reduced by adjusting sowing dates or crop management options. The simple and robust thermal time models will improve production and marketing arrangements, which have to be made in advance. The thermal time models in this study, incorporating frost risk using conditional statements, provide a foundation for a decision support system to manage the sequence of sowings on commercial broccoli farms.
1999-01-01Publisher
University of Sydney. Land and FoodLicence
Copyright Tan, Daniel Kean Yuen;http://www.library.usyd.edu.au/copyright.htmlShare
