http://hdl.handle.net/2123/5996
| Title: | Incorporating operability measures into the process synthesis stage of design |
| Authors: | Padley, Mark Andrew Dept of Chemical Engineering |
| Keywords: | Chemical processes. Process control -- Data processing |
| Issue Date: | 1991 |
| Publisher: | University of Sydney |
| Description: | This thesis was digitised for the purposes of Document Delivery. It is not available on open access and access is restricted. The item may be requested on Interlibrary Loan or viewed in the Rare Book Library at the University of Sydney. If you are the author of this work and would like it to be made available on open access please contact the Sydney eScholarship Repository Coordinator - escholarship.info@sydney.edu.au |
| Access Level: | This thesis was digitised for the purposes of Document Delivery. It is not available on open access and access is restricted. The item may be requested on Interlibrary Loan or viewed in the Rare Book Library at the University of Sydney. If you are the author of this work and would like it to be made available on open access please contact the Sydney eScholarship Repository Coordinator - escholarship.info@sydney.edu.au |
| URI: | http://hdl.handle.net/2123/5996 |
| Department/Unit/Centre: | Dept of Chemical Engineering |
| Rights and Permissions: | The author retains copyright of this material |
| Type of Work: | PhD Doctorate |
| Appears in Collections: | Theses - Interlibrary Loans and Document Delivery (Closed Collection) |
