Metal plasma immersion ion implantation and deposition using polymer substrates
Oates, T. W. HAbstract
This thesis investigates the application of plasma immersion ion implantation (PIII) to polymers. PIII requires that a high negative potential be applied to the surface of the material while it is immersed in a plasma. This presents a problem for insulating materials such as polymers, ...
See moreThis thesis investigates the application of plasma immersion ion implantation (PIII) to polymers. PIII requires that a high negative potential be applied to the surface of the material while it is immersed in a plasma. This presents a problem for insulating materials such as polymers, since the implanting ions carry charge to the surface, resulting in a charge accumulation that effectively neutralises the applied potential. This causes the plasma sheath at the surface to collapse a short time after the potential is applied. Measurements of the sheath dynamics, including the collapsing sheath, are performed using an electric probe. The results are compared to theoretical models of the plasma sheath based on the Child-Langmuir law for high voltage sheaths. The theoretical model predicts well the sheath dynamics for conductive substrates. For insulating substrates the model can account for the experimental observations if the secondary electron coefficient is modified, justified on the basis of the poly-energetic nature of the implanting ions. If a conductive film is applied to the insulator surface the problem of charge accumulation can be avoided without compromising the effectiveness of PIII. The requirement for the film is that it be conductive, yet transparent to the incident ions. Experimental results are presented which confirm the effectiveness of the method. Theoretical estimates of the surface potential show that a film of the order of 5nm thickness can effectively circumvent the charge accumulation problem. Efforts to produce and characterise such a film form the final two chapters of this thesis. The optimal thickness is determined to be near the percolation threshold, where a marked increase in conductivity occurs. Spectroscopic ellipsometry is shown to be an excellent method to determine the film thickness and percolation threshold non-invasively. Throughout this work cathodic vacuum arcs are used to deposit thin films and as a source of metal plasmas. The design and construction of a pulsed cathodic vacuum arc forms a significant part of this thesis. Investigations of the cathode spots and power supply requirements are presented.
2003-01-01Licence
Copyright Oates, T. W. H.;http://www.library.usyd.edu.au/copyright.htmlThe author retains copyright of this thesis
Faculty/School
