The University of Sydney Sydney eScholarship Repository
The Sydney eScholarship Repository >
Science >
School of Biological Sciences >
Research and papers >
Please use this identifier to cite or link to this item: http://hdl.handle.net/2123/5438
Title: The Z stack of a late brachiolaria larva of the asterinid sea star Parvulastra exigua recorded by confocal laser scanning microscopy
Authors: Morris, Valerie B
Keywords: serial imaging
morphogenesis
echinoderm
evolution
Issue Date: 30-Sep-2009
Abstract: The Z stack in this archive is representative of a late brachiolaria larva of P. exigua recorded in the Olympus FluoView 1000 laser scanning system. It is from a study of the morphology of the coeloms and their interconnexions in a pre-metamorphic brachiolaria larva. The data of the Z stack show the coelom on the left and right sides of the larva linked anteriorly, over the head of the archenteron, by a common anterior coelom. The asymmetry of the larger left and the smaller right larval coeloms translates into the oral and aboral coeloms of the juvenile sea star. The morphology of the coeloms in a late brachiolaria larva of an asteroid has application in the search for morphological homology between the echinoderm classes and the deuterostome phyla. ***** Late brachiolaria larvae of P. exigua were fixed seven days after fertilization in 2.5% (v/v) glutaraldehyde in filtered sea water for 1-2 hours, dehydrated in an ethanol series to 100% ethanol, then cleared in 2:1 (v/v) benzyl benzoate/benzyl alcohol. The larvae, made autofluorescent by glutaraldehyde fixation, were mounted in the clearant in a chamber between glass coverslips that sealed a hole cut through a conventional microscope slide. The larvae were viewed in the Olympus FluoView 1000 laser scanning system (version 1.7.1.0) attached to an Olympus IX81 inverted microscope. Each larva was excited with a 633 nm helium-neon laser with the emission collected from 645-745 nm. A stack of images was collected along the Z axis (the Z stack) with a pixel dimension of 1.24 x 1.24 µm and a slice thickness of 1.10 µm averaged over two frames with a 20x UplanApo objective lens NA 0.7 in a 512 x 512 pixel array, 12 bits/pixel.
Description: The Z stack is a series of images scanned in the XY plane at successive levels through the depth of the body of the larva. The orientation of the larva is such that view is of the larval ventral surface and larval anterior is on the left in each image. Since the images were reflected by the IX81 inverted microscope, the images should be reflected to obtain the correct left-right view. The images are tif images saved in sequence into one folder. Each tif image can be viewed individually or the series of tif images contained in the folder can be analysed by image analysis software such as ImageJ available from the National Institutes of Health site (http://rsbweb.nih.gov/ij/). Scale bar 100 µm.
URI: http://hdl.handle.net/2123/5438
Department/Unit/Centre: School of Biological Sciences
Appears in Collections:Research and papers
ex051008_1sb_c001z001.tifFirst image in the Zstack with a scale bar795.86 kBTIFFThumbnail
ex051008_1avi.zipZipped (compressed) avi video13.11 MBZipView/Open
ex051008_1.aviVideo of Zstack images98.31 MBAVI VideoView/Open
ex051008_1.zipZstack folder (compressed)14.81 MBZip View/Open
