Sydney eScholarship Repository
The Sydney eScholarship Repository >
Linguistics >
Honours Theses >
Please use this identifier to cite or link to this item: http://hdl.handle.net/2123/5385
Title: Negative Evidence in Linguistics: The case of Wagiman Complex Predicates
Authors: Wilson, Aidan
Department of Linguistics
Keywords: wagiman language
Issue Date: 2006
Abstract: In this thesis I will justify the use of negative forms of evidence as a permissible means of analysing grammatical constructions. I do this by presenting a test case, a grammatical construction that is not entirely understood, and attempting to understand and explain further aspects of it by appealing to negative forms of evidence. The constructions that form the object of this investigation are complex predicates in the Wagiman language. It will be necessary first, to provide a detailed explanation of Wagiman complex predicates; the elements that comprise them, the way those elements combine and the limitations that hold on them. Following that, negative evidence of the combinations that are possible and combinations that are impossible will provide the means by which to identify the constraints that limit complex predicates.
URI: http://hdl.handle.net/2123/5385
Department/Unit/Centre: Department of Linguistics
Appears in Collections:Honours Theses
wilson_thesis_2006.pdf462.75 kBAdobe PDFView/Open
