Olfactory discrimination in the rat
Sokolic, LjiljanaAbstract
Abstract Olfactory tasks are used very often with laboratory animals in studies of the neurobiology of learning and memory. Rats and mice are extremely sensitive in their detection and discrimination of odours, learn olfactory tasks rapidly, and can display higher order cognitive ...
See moreAbstract Olfactory tasks are used very often with laboratory animals in studies of the neurobiology of learning and memory. Rats and mice are extremely sensitive in their detection and discrimination of odours, learn olfactory tasks rapidly, and can display higher order cognitive functions in olfactory tasks. This cognitive capacity may rival the ability of primates to learn analogous tasks with visual cues and most likely reflects strong anatomical connections between the olfactory bulbs and higher brain regions such as the piriform cortex, orbitofrontal cortex and hippocampus. The current thesis explored olfactory discrimination learning and performance in rats and had two principal aims. The first part of the thesis was oriented around odour masking phenomena in rats: the ability of one odour in a mixture to suppress detection of a second odour in that mixture. A specialized behavioural paradigm was developed to allow the study of odour masking in the rat. The second part of the thesis was pharmacological and determined whether the acquisition, reversal and performance of olfactory discriminations, and analogous auditory discriminations, are affected by two commonly used classes of drugs (benzodiazepines and cannabinoids). Together, these studies attempt to gain a better understanding of the nature of olfactory discrimination learning in rats, by using both psychophysical and pharmacological approaches, and to develop behavioural paradigms which may be used in future psychophysical and pharmacological studies. Following an introduction and review of olfactory and auditory studies in rat (Chapter 1), odour masking phenomena were studied in Chapter 2. The aliphatic aldehydes butanal (C4) and heptanal (C7) were used in the study. Aldehydes were of interest as this class of odorants abound in nature and may be important for rodents’ species-specific communication. Thirsty rats were initially trained to discriminate C4 and C7 in the olfactometer, using a go/no-go olfactory discrimination task. This involved rats learning to nose poke in an odour port and to lick a tube for a water reward on presentation of the rewarded component S+, while withholding licking at the tube when the other, unrewarded, aldehyde (S-) was presented. Odour mixtures (C4C7 or C7C4) were then introduced into the task as an additional non-rewarded condition (mixture S-). The concentration of the non-rewarded aldehyde in the mixture was then systematically decreased, while the concentration of the rewarded aldehyde was kept constant. When the non-rewarded aldehyde reached a critical low level in the mixture, rats started to make responses to the non-rewarded mixture (false alarms) showing that the S+ odour was suppressing the S- odour in the mixture, so the mixture was being responded to in the same manner as the S+ odour presented alone. Results also showed asymmetric suppression in the mixture condition, such that butanal suppressed detection of heptanal at a much lower concentration than vice versa. A second experiment demonstrated that when both butanal and heptanal were present in a binary mixture at the same concentration (10-6 volume %), rats responded to the mixture as if only butanal was present. Our findings are in agreement with human studies showing component interactions in binary mixtures of aldehydes. The molecular feature of carbon chain length appears to be a critical factor in determining the outcome of interactions between aldehydes at peripheral olfactory receptors, with smaller chain aldehydes better able to compete for receptor occupancy. Subsequent chapters explored the effects of two classes of commonly used drugs - benzodiazepines and cannabinoids - on olfactory and auditory discrimination in rats. Animal models such as the radial arm maze, Morris water maze and object recognition test are routinely used to test adverse and facilitatory effects of drugs on cognition in rodents. However, comparatively few pharmacological studies employ olfactory or auditory go/no-go paradigms. Thus, an important part of the present thesis was to assess the viability of using such paradigms in detecting pharmacological effects, and to identify whether such effects may be modality specific (i.e. whether a drug has a greater effect on olfactory or auditory tasks). In Chapter 3, the effects of benzodiazepines on olfactory discrimination tasks were explored. Rats were injected with the benzodiazepine drugs midazolam or diazepam and tested on discrimination tasks involving either the auditory and olfactory modality. Results showed that midazolam (0.5–2 mg/kg sc) did not affect the performance of a well-learned two-odour olfactory discrimination task, and moderately facilitated the performance of a go/no-go auditory discrimination task. On the contrary, midazolam (1 mg/kg) impaired the acquisition of a novel go/no-go olfactory discrimination task, as well as the reversal of a previously well-learned olfactory discrimination. However, midazolam did not affect the acquisition or reversal of an equivalent auditory discrimination task. The olfactory bulb and the piriform cortex are intimately involved in associative learning and behavioural aspects of olfactory performance, and have high concentrations of benzodiazepine receptors. These may therefore be possible neural substrates for the disruptive effects of benzodiazepines on olfactory learning. Findings from Chapter 4 indicated that the prototypical cannabinoid agonist delta-9-tetrahydrocanabinol (Δ9 THC) (0.3, 1 and 3 mg/kg) impairs auditory discrimination performance, but had no effect on equivalent olfactory discriminations. This is in marked contrast to the effects of benzodiazepines. Residual effects were observed, such that auditory discrimination performance was still impaired on the day following Δ9 THC administration. Delta-9-tetrahydrocanabinol effects were prevented by co-administration of the cannabinoid antagonist rimonabant (3 mg/kg). In addition, the anandamide hydrolysis inhibitor URB597 (0.1 and 0.3 mg/kg), which boosts levels of endogenous cannabinoids in the synapse, also impaired auditory discrimination performance, and this effect was also reversed by rimonabant. This study also assessed the effects of Δ9 THC (0.3, 1 and 3 mg/kg) and URB597 (0.1 and 0.3 mg/kg) on acquisition and reversal of novel olfactory discriminations. Results showed that Δ9 THC impairs olfactory reversal learning without affecting acquisition of the original discrimination. It is argued that this reversal deficit may be part of a wider capacity for cannabinoids to impair cognitive flexibility. The final Chapter (General Discussion) discusses the relevance and implications of the combined findings. The results add significantly to our current understanding of perceptual, learning and memory processes involving the olfactory modality in rats. With respect to olfactory perception, this thesis introduced a new behavioural paradigm, which can be used to assess component suppression in mixtures, and may be of use in future psychophysical studies involving rodents or other species. With respect to learning and memory, the thesis provides novel information on the disruptive effects of benzodiazepines and cannabinoids on olfactory and auditory tasks. It is concluded that go/no-go olfactory and auditory discrimination tasks in rats can provide a useful platform for assessing the disruptive and modality-specific effects of drugs on learning, performance and cognitive flexibility. Future studies might expand the range of drugs tested on these paradigms and might consider chronic as well as acute drug effects.
2008-10-01Licence
