Microbial and Geochemical aspects of Selenium cycling in an Estuarine system: Lake Macquarie N.S.W.
Carroll, Brett IanAbstract
ABSTRACT This work examined the role of micro-organisms in the biogeochemical cycling of selenium within the benthic ecosystem of Lake Macquarie, a coastal lake in New South Wales with a history of anthropogenic heavy metal contamination. Certain micro-organisms possess the ...
See moreABSTRACT This work examined the role of micro-organisms in the biogeochemical cycling of selenium within the benthic ecosystem of Lake Macquarie, a coastal lake in New South Wales with a history of anthropogenic heavy metal contamination. Certain micro-organisms possess the ability to oxidise or reduce selenium (Fleming and Alexander, 1973; Doran and Alexander, 1977), and microbial volatilisation of selenium from contaminated sediments and soils utilising naturally-occurring microflora has been shown in overseas research (Thompson-Eagle and Frankenberger, 1992) to be a potentially effective remediation strategy. In examining the impact of micro-organisms upon the oxidation state of selenium in Lake Macquarie sediments, this work also investigated and characterised selenium (and heavy metal) concentrations, speciation and geochemical phase associations (an indicator of potential bioavailability) in the sediments. Seven distinct bacterial species indigenous to Lake Macquarie were identified in this work with the ability to reduce selenium as selenite to elemental selenium, and selenium as selenate to organic forms of selenium, including volatile methylated selenium compounds. Metabolic parameters calculated for these organisms compared favourably with those reported in the literature by other researchers. Mixed populations of sediment micro-organisms were also isolated and studied in this work for their selenite and selenate reduction abilities. Total reduction of added selenite at levels up to 100 mg/L was recorded for a number of the organisms studied in this work. A maximum specific uptake rate for selenite of 3040 mgSe(IV).(gcells)-1.(h)-1 for one isolate (Shewanella putrefaciens) was determined, exceeding rates reported in the literature by other authors. Use of the indigenous micro-organisms from Lake Macquarie for the bioremediation of selenium containing waste streams was also examined in this work and selenium reduction in an immobilised cell reactor was demonstrated with such organisms. Concentrations, speciation, sediment core profiles and geochemical phase associations for selenium were determined for sediment samples collected at a variety of sites throughout Lake Macquarie and from Wyee Creek, a selenium-impacted fluvial input to the lake. The maximum concentration of selenium obtained in this work for the lake proper was 4.04 mg/kg, considerably lower than values reported over a decade ago (Batley, 1987) but consistent with reported reductions of selenium input into the lake from the lead-zinc smelter. Selective extraction methodology (Tessier et al. and BCR methods) studied geochemical phase association of selenium in Lake Macquarie sediments and found up to 44% of selenium was in bioavailable forms. Of interest and environmental concern was levels of selenium found in sediments of Wyee Creek, which previously received overflows from the ash dam associated with the Vales Point Power Station. Sediment selenium levels of up to 300 mg/kg were determined for this creek. These were an order of magnitude or more greater than those recorded for the lake itself and are of concern as to the potential impact on benthic organisms and those animals, including humans, who consume them. While this work can only provide a 'snapshot' of conditions within Lake Macquarie at the time of the sampling events recorded herein, it does make several important contributions to the understanding of selenium biogeochemistry in Lake Macquarie. These include: presentation of the hypothesis that selenium levels in surficial sediments being deposited in the north of the lake have decreased in recent years as a result of selenium reduction measures undertaken by the lead-zinc smelter; determination that up to 44% of selenium in surficial sediments from the lake is associated with sediment phases in which selenium has the potential to become remobilized and hence possibly bioavailable; and documentation of selenium concentrations in Wyee Creek, identifying the area as having selenium concentrations an order of magnitude or more greater than the lake itself. Concerning the role played by microorganisms in the biogeochemical cycling of selenium in Lake Macquarie, this work has: identified individual isolated and mixed cultures of bacteria that can reduce selenium as selenite to lower oxidation states; identified individual isolated and mixed cultures of bacteria that can reduce selenium as selenate to lower oxidation states; identified volatile methylated selenium compounds in the headspace gases of microorganisms reducing selenate; determined Minimum Inhibitory Concentrations for selenate and selenite for organisms isolated from Lake Macquarie; identified casein hydrolysate as a preferred carbon source for selenium reducing microorganisms from Lake Macquarie; and demonstrated that bioremediation of selenium contaminated waste streams using indigenous organisms from Lake Macquarie is feasible on the laboratory scale. Further research areas suggested by this work include: additional investigations of elevated selenium levels in Wyee Creek sediments; determination of the role of microbes in in-situ selenium reduction; and optimisation of selenium biotreatment/bioremediation of selenium-containing waste streams and sediments. In summary, this work, in rejecting the null hypothesis that the oxidation states of selenium in sediments from Lake Macquarie, NSW, are independent of microbial activity and accepting the alternate hypothesis that these oxidation states are not independent of microbial activity, contributes to the understanding of the role of microorganisms in the biogeochemical cycling of selenium, having applicability to both the specific ecosystem of Lake Macquarie, NSW, and also to selenium cycling in the environment in general. In addition, this work has identified selenium contamination in Wyee Creek, one of the fluvial inputs to Lake Macquarie, which was previously been undocumented in the literature and which may pose significant potential risk to humans and the ecosystem due to sediment selenium levels one or more orders of magnitude higher than those recorded in the lake itself. Finally, this work has also identified a number of microorganisms indigenous to Lake Macquarie with the ability to reduce selenium from toxic, mobile forms to less toxic, immobile or volatile forms, and these organisms have been shown to have the potential for use in treatment of selenium contaminated waste streams and also in the bioremediation of selenium-contaminated sediments.
1999-01-01Licence
Copyright Carroll, Brett Ian;http://www.library.usyd.edu.au/copyright.htmlFaculty/School
Department of Chemical EngineeringAwarding institution
