The interaction of local and overall buckling of cold-formed stainless steel columns.
Becque, JurgenAbstract
Abstract: The objective of this research is to investigate the interaction of local and overall flexural buckling in cold-formed stainless steel columns. Literature study exposes a lack of understanding of this subject and a need for experimental data, particularly on the local-overall ...
See moreAbstract: The objective of this research is to investigate the interaction of local and overall flexural buckling in cold-formed stainless steel columns. Literature study exposes a lack of understanding of this subject and a need for experimental data, particularly on the local-overall interaction buckling of stainless steel open sections. Two separate experimental programs were therefore carried out. The first program included 36 tests on pin-ended lipped channel columns. Three alloys were considered: AISI 304, AISI 430 and 3Cr12. The specimens were designed to fail by local-overall interaction buckling in the inelastic stress range, thus highlighting the non-linear behaviour of stainless steel. Half of the specimens were tested under a concentric load. The other half had the load applied with a nominal eccentricity of Le/1500. The test results demonstrate the imperfection sensitivity of local-overall interaction buckling and illustrate the shift in effective centroid in pin-ended columns with singly symmetric cross-section. The second experimental program studied local-overall interaction buckling in 24 pin-ended stainless steel I-section columns. The specimens consisted of plain channels connected back-to-back using sheet metal screws. Two alloys were considered: AISI 304 and AISI 404. Local and overall imperfections were carefully measured in both experimental programs. Extensive material testing was carried out on the alloys employed in the experimental program, in order to determine tensile and compressive material properties, anisotropic parameters and enhanced corner properties. A detailed finite element model is presented, which includes non-linear material behaviour, anisotropy, increased material properties of the corner areas and local and overall imperfections. The model was verified against the two aforementioned experimental programs and against additional data available in literature on stainless steel SHS columns. The model yielded excellent predictions of the specimen failure mode, ultimate strength and load-deformation behaviour. The finite element model was used to generate additional data for stainless steel columns with lipped channel, plain channel, SHS and I-shaped cross-section, failing by local-overall interaction buckling. The parametric studies covered the practical ranges of overall and cross-sectional slenderness values. The Australian/New Zealand, European and North American standards for stainless steel were evaluated using the available data. The comparison reveals an inability of the design codes to properly account for the interaction effect as the cross-sectional slenderness increases. Predictions are unsafe for I-section columns with intermediate or high cross-sectional slenderness. A direct strength method is proposed for stainless steel columns, accounting for the local-overall interaction effect. The method offers a simple design solution which fits within the framework of the current Australian and North-American standards.
2008-09-01Licence
