Wide Field Aperture Synthesis Radio Astronomy
Bock, Douglas Carl-JohanAbstract
This thesis is focussed on the Molonglo Observatory Synthesis Telescope (MOST), reporting on two primary areas of investigation. Firstly, it describes the recent upgrade of the MOST to perform an imaging survey of the southern sky. Secondly, it presents a MOST survey of the Vela ...
See moreThis thesis is focussed on the Molonglo Observatory Synthesis Telescope (MOST), reporting on two primary areas of investigation. Firstly, it describes the recent upgrade of the MOST to perform an imaging survey of the southern sky. Secondly, it presents a MOST survey of the Vela supernova remnant and follow-up multiwavelength studies. The MOST Wide Field upgrade is the most significant instrumental upgrade of the telescope since observations began in 1981. It has made possible the nightly observation of fields with area ~5 square degrees, while retaining the operating frequency of 843 MHz and the pre-existing sensitivity to point sources and extended structure. The MOST will now be used to make a sensitive (rms approximately 1 mJy/beam) imaging survey of the sky south of declination -30°. This survey consists of two components: an extragalactic survey, which will begin in the south polar region, and a Galactic survey of latitudes |b| < 10°. These are expected to take about ten years. The upgrade has necessitated the installation of 352 new preamplifiers and phasing circuits which are controlled by 88 distributed microcontrollers, networked using optic fibre. The thesis documents the upgrade and describes the new systems, including associated testing, installation and commissioning. The thesis continues by presenting a new high-resolution radio continuum survey of the Vela supernova remnant (SNR), made with the MOST before the completion of the Wide Field upgrade. This remnant is the closest and one of the brightest SNRs. The contrast between the structures in the central pulsar-powered nebula and the synchrotron radiation shell allows the remnant to be identified morphologically as a member of the composite class. The data are the first of a composite remnant at spatial scales comparable with those available for the Cygnus Loop and the Crab Nebula, and make possible a comparison of radio, optical and soft X-ray emission from the resolved shell filaments. The survey covers an area of 50 square degrees at a resolution of 43" x 60", while imaging structures on scales up to 30'. It has been used for comparison with Wide Field observations to evaluate the performance of the upgraded MOST. The central plerion of the Vela SNR (Vela X) contains a network of complex filamentary structures. The validity of the imaging of these filaments has been confirmed with Very Large Array (VLA) observations at 1.4 GHz. Unlike the situation in the Crab Nebula, the filaments are not well correlated with H-alpha emission. Within a few parsec of the Vela pulsar the emission is much more complex than previously seen: both very sharp edges and more diffuse emission are present. It has been postulated that one of the brightest filaments in Vela X is associated with the X-ray feature (called a `jet') which appears to be emanating from the region of the pulsar. However, an analysis of the MOST and VLA data shows that this radio filament has a flat spectral index similar to another more distant filament within the plerion, indicating that it is probably unrelated to the X-ray feature.
1997-01-01Licence
Copyright Bock, Douglas Carl-Johan;http://www.library.usyd.edu.au/copyright.htmlFaculty/School
