A search for nu(mu) to nu(e) oscillations in the NOMAD experiment
Godley, AndrewAbstract
The NOMAD experiment is a neutrino oscillation experiment, capable of identifying \nm, \nmb, \nel, \neb\ and \nt\ for use in oscillation analyses. A search for \mutoe\ oscillations is conducted, emphasising the development of two separate beam simulators, to provide the background, ...
See moreThe NOMAD experiment is a neutrino oscillation experiment, capable of identifying \nm, \nmb, \nel, \neb\ and \nt\ for use in oscillation analyses. A search for \mutoe\ oscillations is conducted, emphasising the development of two separate beam simulators, to provide the background, (no oscillation), \nel\ signal. Both beam descriptions include fits to the results of the SPY experiment that measured hadron production from a 450~GeV proton beam on beryllium target. An independent analysis of the raw SPY data to produce the particle yield is reported. A series of criteria are described for the selection and classification of neutrino events. These produce the data samples necessary for both tuning the beam simulation and determining the oscillation signal. The development of a GEANT and FLUKA based Monte Carlo beam simulator is presented, providing good agreement to the measured neutrino beam. This simulation method has sizeable variations depending on the beamline geometry, which is not known precisely. This causes large systematic errors. An empirical parametrisation is proposed and used for the first time in a NOMAD oscillation search. It uses the measured neutrino spectra at NOMAD, except the \nel, to infer the meson production at the target, and then predict the \nel\ spectrum. This method has good agreement with the data and is also insensitive to alterations of the beamline geometry, resulting in much smaller systematic errors. The reduction of the systematic errors allows the \mutoe\ oscillations search to be performed with much greater precision. Comparisons of the \nel/\nm\ ratio between the empirical parametrisation and data yields no evidence for \mutoe\ oscillations, setting a limit on the mixing parameter, $sin^2(2 \theta) < 1.9 \times 10^{-3} \mbox{(90\% CL)}$ at high $\Delta m^2$. The present sensitivity of the analysis on the mixing parameter is 0.0017.
2000-01-01Licence
Copyright Godley, Andrew;http://www.library.usyd.edu.au/copyright.htmlFaculty/School
