The Murray River Turtle, Emydura macquarii: Population Dynamics, Nesting Ecology and Impact of the Introduced Red Fox, Vulpes vulpes
Spencer, Ricky-JohnAbstract
I studied aspects of the ecology of the Murray River turtle, Emydura macquarii, to determine the impact of the introduced red fox, Vulpes vulpes. The fox is one of Australia's worst vertebrate pests through its predation on livestock and native mammals, but their impact on reptilian ...
See moreI studied aspects of the ecology of the Murray River turtle, Emydura macquarii, to determine the impact of the introduced red fox, Vulpes vulpes. The fox is one of Australia's worst vertebrate pests through its predation on livestock and native mammals, but their impact on reptilian communities is not known. I conducted a large-scale mark-recapture study to evaluate population growth of E. macquarii in the Albury region of the upper Murray River by determining growth, reproduction and survival. The study was conducted downstream of the first, and largest, impoundment on the Murray River, Lake Hume. Emydura macquarii predominantly inhabit the lagoons in the upper Murray River, as the mainstream and Lake are possibly too cool to maintain metabolic processes. They are easily captured in hoop traps and the use of live decoys maximises trap success. Over 2000 hatchling turtles were marked and released into two lagoons between January 1997 and January 1998. Growth of these individuals is rapid over the first few years but declines towards maturity, and is indeterminate after maturity. Although growth annuli are not well defined, even on young individuals, the von Bertalanffy model describes the growth of both male and female E. macquarii. Male turtles mature at 5-6 years and females mature at 10-12 years. Female turtles may maximise reproductive potential by delaying maturity and producing one relatively large clutch (mean = 21 eggs) per year, which is positively correlated with body size (PL). Although primarily related to body size, clutch size varies annually because of environmental conditions. If winter and summer rainfalls are below average and temperatures are above average, E. macquarii may reduce clutch size to increase the chance of the eggs surviving. Nesting predominantly occurs during the first major rain-bearing depression in November. Habitat variables, including distance from water, nearest nest, and tree, and soil type were measured for each nest to determine characteristics that attract predators. Nests close to the shoreline and trees are heavily preyed on, and nests constructed in sand are less likely to be destroyed by predators. Foxes detect nests through a combination of chemical cues from eggs and slight soil disturbances, whereas birds only destroy nests observed being constructed during the day. Female turtles alter nesting behaviour and construct nests much further away from water when foxes were removed and as a result, nests are less dense and away from trees. Thus in high predation risk areas, turtles minimise emergence and search times to reduce the risk of direct predation by foxes. Predation is reduced when nests are in lower densities and away from trees, because predators increase search efforts when nests are in higher densities and birds are more likely to destroy nests close to trees. Reproductive success is further reduced in high predation risk areas because more nests are constructed in sandy substrates where clutch success is reduced compared to incubation in more dense substrates. Where predators are a significant source of mortality, prey may use indirect methods, such as chemical recognition, to avoid encounters. Nesting turtles did not avoid areas where fox odour was present, suggesting that they assess predation pressure from foxes by other mechanisms, such as visual recognition. However, an innate response occurs to the odour of a once common predator on the Murray River, the eastern quoll (Dasyurus viverrinus), whereby turtles recognise and avoid nesting in areas where quoll odour is present. Therefore nesting turtles show a similar avoidance response to two different predators, using different mechanisms of detection. Similarly, predation risk may influence hatching times and nest emergence. The rate of embryonic development of E. macquarii may increase or eggs may hatch early so that the clutch hatches synchronously, thereby reducing the risk of predation through group emergence from the nest. Emydura macquarii reach densities of over 100 turtles.ha-1, with the majority of the population consisting of sexually mature individuals. Emydura macquarii has a Type III survival curve where mortality is extremely high in the egg stage (93% nest predation), remaining high over the hatchling stage (minimum survival rate- 10%), but decreasing rapidly throughout the juvenile stage (~70% juvenile survival). Adult survival is extremely high, with greater than 95% of adults surviving each year. Foxes through nest predation cause most mortality but a small proportion (~3%) of nesting adult females are killed by foxes each year. A removal program evaluated the impact of foxes. In 1996, fox numbers were monitored around four lagoons by spotlighting and non-toxic bait uptake. Foxes were removed from around two of the lagoons throughout 1997 and 1998, using spotlight shooting and 1080 bait poisoning. Fox numbers were continually monitored around all four lagoons during the study. Nest predation rates remained around 90% in all sites where foxes were present, but fell to less than 50% when foxes were removed. At the same time, predation on nesting female turtles was eliminated where foxes were removed. Demographic models using staged based survival schedules, together with growth and fecundity values for E. macquarii show a decline of 4% per year in these populations. Elasticity analyses shows that survival of adult female E. macquarii has the major influence on population stability and a reduction of nest predation alone is unlikely to address the population decline. Management options, such as reducing foxes prior to nesting around key lagoons, will stabilise the population decline, and eliminating foxes completely from certain areas with high dispersal potential, will promote recruitment of juvenile E. macquarii.
2000-01-01Licence
Copyright Spencer, Ricky-John;http://www.library.usyd.edu.au/copyright.htmlFaculty/School
Faculty of Science, School of Biological SciencesAwarding institution
