Please use this identifier to cite or link to this item: http://hdl.handle.net/2123/3567
Title: Rebuilding Shakespeare’s theatre (and how to show your workings)
Authors: Fitzpatrick, Tim
Department of Performance Studies
Keywords: performance studies
Issue Date: 8-Oct-2008
Abstract: This is an attempt to use—and assess the usefulness of—PowerPoint as a means of presenting research which involves a high degree of visual imaging. Working from the only available 17 th century sketch of Shakespeare’s second Globe playhouse, the research project attempted to theorise the architectural structure of the sketched building, and then use computer-aided design to build and test the validity of that theorised structure. When the resultant artifact was then compared with the original sketch, the congruences and discrepancies were very interesting. Powerpoint (which I generally loathe and detest when used inexpertly in lecturing) turns out to be a reasonably flexible tool for presenting this sort of research.
Description: Tim Fitzpatrick is Associate Professor in the Department of Performance Studies. This seminar was presented as part of the series "Visual representation in research" on 15 August 2008.
URI: http://hdl.handle.net/2123/3567
Department/Unit/Centre: Department of Performance Studies
Appears in Collections:DIU Presentations
fitzpatrick_15_8_08.aviAudio recording79.29 MBaviView/Open
fitzpatrick_TF INTRO TO GLOBE (2).pptIntroductory PowerPoint presentation565 kBMicrosoft PowerpointView/Open
fitzpatrick_TF+RE RECONSTRUCTING HOLLAR'S GLOBE.pptPowerPoint presentation of the project7.93 MBMicrosoft PowerpointView/Open
