Please use this identifier to cite or link to this item: http://hdl.handle.net/2123/3540
Title: Entrainment to extinction of physiological tremor by spindle afferent input
Authors: Cathers, Ian
O'Dwyer, Nicholas
Neilson, Peter
Discipline of Exercise and Sport Science
Faculty of Health Sciences
Keywords: stretch reflex
tremor
coupled oscillators
neural modeling
wrist
electromyography
Issue Date: 2006
Publisher: Springer Verlag
Citation: Ian Cathers, Nicholas O’Dwyer, Peter Neilson (2006) Entrainment to extinction of physiological tremor by spindle afferent input. Experimental Brain Research, Volume 171, Number 2 / May, 2006. Pages 194-203. The original publication is available at www.springerlink.com.
Abstract: In this study the systematic modulation of wrist flexor muscle activity by imposed joint movement was examined. Ten subjects maintained a constant contraction level (25% of maximum; trial duration: 20 s) in flexor carpi radialis while their wrists were perturbed with 50 different quasi-sinusoidal signals (frequency range: 0.5 - 9.5 Hz; amplitude: 0.3° - 4.2°). Frequency spectra of wrist position and the rectified and filtered electromyogram (EMG) were determined. The muscle activity was only weakly entrained to imposed movements of small amplitude and low frequency, as shown by a small peak in the EMG spectrum at the frequency of movement, while the most prominent peak in the spectrum was between 9 - 15 Hz, corresponding to the frequency range of physiological tremor. The entrainment of muscle activity increased markedly as the amplitude and frequency of the imposed movement increased, to the point of saturation of modulation and harmonic peaks in the spectrum. In parallel with this increase in entrainment, the 9 - 15 Hz tremor peak was progressively extinguished. The results are consistent with a coupled oscillator model in which the central oscillatory source(s) of tremor became fully entrained to the imposed movement at the highest amplitudes and frequencies. Such coupling depends on communication between the external forcing oscillator and the central oscillator(s), the Ia afferent signal from the imposed movement being the most likely candidate to provide the entraining signal for the central oscillator(s).
URI: http://hdl.handle.net/2123/3540
ISSN: 0014-4819
Department/Unit/Centre: Discipline of Exercise and Sport Science
Appears in Collections:Research Papers and Publications. Discipline of Exercise and Sport Science
Cathers_etal_2006.pdf320.94 kBAdobe PDFView/Open
