Cationic Oligomeric Surfactants: Novel Synthesis and Characterization
Topp, Kathryn AlexandraAbstract
Oligomeric surfactants, sometimes referred to as gemini surfactants, consist of two or more amphiphilic ‘monomer’ units linked together by spacer groups. The chemical identity of the spacer group is unconstrained, and it joins the individual units at or near the hydrophilic headgroups. ...
See moreOligomeric surfactants, sometimes referred to as gemini surfactants, consist of two or more amphiphilic ‘monomer’ units linked together by spacer groups. The chemical identity of the spacer group is unconstrained, and it joins the individual units at or near the hydrophilic headgroups. Oligomeric surfactants display a range of interesting properties, including very low critical micelle concentrations, high surface activity and unusual rheology and self-assembly. Consequently they have many potential applications, both scientific and industrial. Until now, their use has been limited by the cost of their synthesis, which in some cases involve long and difficult procedures. This project developed from the idea that a synthesis based on polymerization could prove a useful and versatile method for producing these surfactants. The chemical starting point for this project was a series of polymerizable surfactants (‘surfmers’), upon which polymerization was performed. Two families of surfmers were investigated, both cationic and based on methacrylate and vinylpyridinium moieties respectively. The physical behaviour of these surfactants – a number of which are new – was investigated using standard techniques; these included the determination of the critical micelle concentration, characterization of phase behaviour, neutron scattering and surface adsorption. In producing oligomers, the initial focus was on free-radical polymerization, with control of molecular weight to be achieved by chain-transfer techniques. Due largely to analysis problems, this work proved unsuccessful. In its place a new reaction, not based on conventional polymerization methods, has been developed. The vinylpyridinium surfmers mentioned above readily undergo addition across the double bond to produce alkyl ring substituents. Under basic conditions, these alkylpyridiniums undergo an elimination/addition reaction in which they link together to form oligomers. This reaction can be started or stopped by raising or lowering the pH of the reaction solution, and has been performed in both organic and aqueous solutions. It is referred to in this thesis as LELA(Linkage by ELimination/Addition). The LELA reaction was used to produce mixtures of oligomers, the phase behaviour and surface adsorption of which were examined. Small-angle neutron scattering was used to monitor the reaction in real time and identify changes in self-assembly as the average oligomer length increased. Progress was also made towards a chromatographic protocol that would allow mixtures to be separated into their components and the pure oligomers to be studied. Finally, some of the compounds studied display interesting pH-dependent chromophoric properties which were also found to occur with other simple alkylpyridinium species. They are tentatively ascribed to inter- and intramolecular charge-transfer complexes, and evidence towards this conclusion was collected and is presented along with relevant calculations.
2006-04-01Licence
