Development of New Cooling Methods for Grinding
Nguyen, ThaiAbstract
This research aimed to develop new cooling methods to replace, or at least minimise, the use of currently used grinding coolants which are known to be harmful to the environment. The methods used involved the application of a cold air and vegetable oil mist mixture (CAOM), and the ...
See moreThis research aimed to develop new cooling methods to replace, or at least minimise, the use of currently used grinding coolants which are known to be harmful to the environment. The methods used involved the application of a cold air and vegetable oil mist mixture (CAOM), and the use of liquid nitrogen as cooling media. Allied research focused on the development of a segmented grinding wheel equipped with a coolant chamber. The feasibility of a grinding system using CAOM was assessed on the surface grinding of plain carbon steel 1045. It was found that at low material removal rates, ground surfaces were obtained with a quality comparable to that from grinding with a conventional coolant in association with a reduction of grinding forces. There was no significant difference in the subsurface hardness of the components using CAOM, although the latter method showed a stronger dependence of surface residual stresses on the depth of cut due to the limit in cooling capacity of CAOM. The effects of using liquid nitrogen as a cooling medium on the microstructure of quenchable steel were explored. It was found that a martensite layer was induced on the ground surface. The microstructure featured a dispersion of very fine carbides within the martensite lattice, resulting in a remarkable increase in hardness and high compressive residual stresses within the layer. The topography of the ground surfaces indicated that the material was predominantly removed by brittle fracture. Furthermore surface oxidisation was suppressed. In the interest of coolant minimisation, a segmented wheel equipped with a pressurized coolant chamber was developed. A higher quality ground surface was obtained in conjunction with a coolant saving of up to 70%. In addition, the adhesion of ground chips on the wheel surface largely disappeared. Furthermore, surface tensile residual stresses caused by thermal deformation were minimised. The mechanism of coolant disintegration to form mists using this type of wheel system was studied. The Weber theory for Newtonian jet instability was applied to quantitatively determine the contribution of coolant flow rate to mist and ligament modes. A semi-analytical model was then developed to predict the mist flow rate by taking into account both grinding parameters and coolant properties. The model prediction was in agreement with experimental measurements. Based on the principles of fluid motion and the mechanisms of spin-off and splash, analytical models for both conventional and segmented wheels were established to provide a physical understanding of the mechanisms of coolant penetration into the grinding zone. Coolant minimisation was evident using the segmented wheel where the coolant pumping power into the grinding zone increased with wheel speed, but for the conventional wheel it decreased. A quantitative analysis was developed that accounted for the coolant properties and system design characteristics governing the penetration mechanism revealed by the theory established above. In conjunction with the mist formation analysis, the developed model offers a practical guideline for the optimal use of grinding coolants in achieving a balance between the demands of productivity and care for the environment.
2005-03-30Licence
Faculty of Engineering, School of Aerospace, Mechanical and Mechatronic EngineeringAwarding institution
